Results 1 to 12 of 12
Thread: Glass tile pool - Any concerns with Robotic Cleaners?
    Jul 2016
    Miami, FL
    3
    Hello all...I'm close to pulling the trigger on a robotic cleaner, but wanted to ask the experts if there are any considerations/concerns or anything special I need to be aware of since I have a glass tile pool.
    I'm thinking about the Dolfin Active 20 or 30 and saw something about the Maytronics "Wonder Brush"? Is that required/recommended/necessary?
    Thank you all in advance for your assistance.
    JG
    31,199
    Re: Glass tile pool - Any concerns with Robotic Cleaners?
    All robots will perform just fine on a glass tile pool.
    I have the S300 and glass mosaic. No issues whatsoever.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jul 2016
    Miami, FL
    3
    Thank you both! Just ordered an Active 20 and am looking forward to the robotic adventure!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,976
    That's a good one!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,214
    Ah, that's my Earl's 1st cousin. I need to go pull Earl out now.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Killer95Stang's Avatar
    Sunny SoCal
    749
    If you watch videos on YouTube from Maytronics on any of the S series robots (Active 20,30 , discovery, s300..) the pool in videos is a glass tile pool.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Quote Originally Posted by JGeorge027 View Post
    JG
    The all foam wonder brush things on the rollers are for extra climbing ability on slick surfaces in different pools. Very expensive too.
    Essential Links:
    Jul 2016
    Miami, FL
    3
    Active 20 (not yet named) arrived Saturday and I put 'em through about 4 or 5 cycles over the weekend. Works beautifully!!! Thanks to all for the assistance!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Congrats! Hope you love him. Her...
    Essential Links:
    Dec 2015
    Newport Beach, CA
    79
    I have an all glass tile pool and the Dolphin Maytronics m500 doesn't climb the walls with the pleated filter. It sometimes climbs the walls with the non pleated filter but significantly less often that I was hoping for. I have rounded corners where the floor meets the wall so not sure if that is causing the problem I did purchase from Marina Pool in CO and they have been awesome.
    Approx. 13,500 gallons above ground
    All glass tile
    Hayward DE Filter, Hayward VS Pump- (pool filter), Hayward VS Pump (neg edge overflow)
    Date of pool build: 2018
    Spa, Ozone UV, Autochlorination, AutoPH, Autofill, Omnilogic, Taylor K-2006
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,185
    I have a dolphin db3 which is a pool builders model here. It climbs the walls but wonít climb all the way to the top if the bag isnít perfectly clean upon starting the cycle. I tend to clean mine at the end of each cycle so itís good to go next time. I donít have the pleated filter just the bag. Also have rounded bottom where floor meets walls and it handles it beautifully. Will get right up the waterline tile and clean under the coping.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
