Thread: CYA, CH down. What happened?
    Sep 2016
    7
    I've experienced an interesting anomaly over the past few months. Back in April I did the complete measurement suite and found that my CH had plummeted to near baseline, and CYA had plummeted to <30 compared to the previous measurements in February. I immediately suspected a leak to the pool or plumbing and so shut off the auto-filler to begin diagnosing the problem (using the bucket test to measure evaporation).
    No discernible leak.
    Has anyone seen this before? Any speculation on what might have happened?
    TIA for any and all ideas.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: CYA, CH down. What happened?
    Speculation, yes.
    CYA will break down a few PPM per month naturally. Faster if certain bacteria get in the pool and chlorine levels aren't high enough to kill it and it starts eating it.
    If the water isn't leaking out and being replenished, then the CH is still there -- most likely as scale on the walls. Do you see any greyish- tan patches? Feel any roughness?
    Sep 2016
    7
    You may be right, Richard. At this point all I can do it monitor it. If it turns out to be something else I'll report back to the group.
    Sep 2016
    7
    Update. Turned out to be a broken autofill valve. I'd noticed the water levels were high for a few months but thought it was due to rain. The water was leaking out at the top of the tile (between it and the apron). Replaced the autofill valve and everything is back to normal.
