Thread: Main drain question.
    I been working on my pool for that past few day now and uncovered the "main drain" cap, but I don't think it's a drain at all. The pool man in the past never used the "main drain" they always used a pump. Now it just looked like concrete that was closing tightly into a small hole. All there is on top is the top cover and ring thats it. nothing inside. I don't even know if there is a drain in my pool. But when my dogs hair hits the pool it flows to the main drain. I'm lost here..... Shold I cap it completely off of what. Here's a picture on it.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Main drain question.
    That's a main drain, or was. There isn't a pipe along the side of that hole anywhere? Perhaps it was filled in before because of a leak.
    If you do manage to find a pipe in there and get it working, it would be a good idea to change your main drain cover to one of the VGB compliant ones. The one you've got is a particularly notorious offender.
    i will look at it again after work. but if its plugged like you said can i just cap it off with a cover instead of the one that is on there?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    If the suction port is plugged I'd recommend either using the existing grate or at least something that will allow a little water through. Odds are there's at least a functioning hydrostatic valve down there and it would be best not to block that.
