Thread: screenlogics not connecting
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    I just installed a screenlogic2. now my problems all started, I am running EL Capitan on my IMAC and it can connect all I get is system not found, So I tried it on my laptop with Windows 10 and get the same thing. Also when I look at my serial # on my protocol adapter it only has 9 numbers. I have tried to reset the PA and no change.
    PS it still says no system found on my Ipad and android phone.
    Have I just thron 385$ out the window or what.The interface mod shows transmitting and receiving
    edit font Jim R.
    Walt Lukowski
    Southern California
    Salt water pool at 24000 gal. new whisperflo variable speed pump. 60 gal. per min.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,291
    Re: screenlogics not connecting
    Ski,
    Please don't use large font...
    If I remember correctly it does not really want the S/N, but rather the hex code next to it... Something like Pentair: F5-XX-XX... (and a space between the : and the F...)
    Dec 2014
    Riverside California
    494
    Also, when entering the hex alpha characters use uppercase.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    wbrewski's Avatar
    Apr 2016
    Santa Ana
    62
    Great , thanks I will try it Wed. my day off.
    Walt Lukowski
    Southern California
