Results 1 to 7 of 7
Thread: TF-100 Cyanuric Acid Test Results
    Sep 2016
    Barrington, IL
    8
    Did this test several times inside my house with a sample from the pool. Every time the black dot never disappeared. Does this mean that I have extremely low cyanuric acid?
    Chicago burbs
    vinyl pool/40k gallons/sand filter
    Re: TF-100 Cyanuric Acid Test Results
    Yes, does that match what you were expecting?
    Support the site
    JoyfulNoise's Avatar
    May 2015
    14,077
    The test bottoms out at 30ppm. So if you have less than that, it would look like zero.
    BUT, the test is meant to be done in outdoor bright lighting, not indoor lamp light. You should redo the test during the day. High noon sun works best. Back to the sun, tube at waist height, and only two fingers pinching the very top of the tube (you do not want to obstruct the entry of light).
    Redo the test before making any chemical additions.
    Matt
    Sep 2016
    Barrington, IL
    8
    I did the test under a can light so don't think it will be much different but I will try it out. What is a desired level for a SW pool and is lower better or worse?
    Chicago burbs
    Akathisia's Avatar
    Jul 2015
    Davis, CA
    130
    It makes a big difference. You want your back to the sun with tube down at your waist like JoyfulNoise advised. Under a can light or facing the sun the black dot can stay visible longer and give a false low reading.
    23k gal IG, plaster; IntelliPro 4 x 160 Variable Speed; STA-RITE S7M120 300 sqft cartridge filter; Intellichlor IC40 SWG; Pentair EasyTouch; Maytronics Dolphin Triton Plus robotic cleaner named "Domo" (arigato Mr. Roboto); Hot Spring Vanguard Spa, TF-100 test kit w/SpeedStir, SampleSizer w/Taylor Calibrated Cylinders and FlowVis Flow Meter from TFTestkits.net. Auto fill and Auto drain. Chlorine / CYA Chart
    May 2015
    14,077
    Quote Originally Posted by Humby81 View Post
    The two (sunlight versus a can-light) can not even be compared. A bright sunny day (in indirect sun) has a luminous output of nearly 11,000 lux (>1000 foot-candle) while standard indoor lighting has a luminous output of 150-250 lux. Even an overcast day has 4X the luminous output of a ceiling light (~1000 lux versus 250 lux).
    The test should be done outdoors in bright lighting to achieve proper results. As for recommended levels, please see this Pool School Article - Pool School - Recommended Levels
    Matt
    30,941
    Please read "The "ABC's of Pool Water Chemistry" up in Pool School.
    The TF-100 takes a larger sample and has good resolution down to 20 ppm. The k-2006 goes down to 30 ppm
