Thread: High Salt Levels
    May 2017
    Indianapolis
    10
    High Salt Levels
    My pool company started up our brand new Salt water pool 2 weeks ago. All levels are balanced within range (I have been testing with Taylor). However, i just received my Taylor Sodium Chloride test add-on test.
    Sodium Chloride is coming in at 4,200 to 4,400. I emailed pool company today, but curious your thoughts. What are the dangers of running high? Do I need to drain and refill some water?
    SWG - 18,500 Gallon Fiberglass
    In Ground
    Pentair Intellicor Salt Generator
    Midwest Location
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    10,952
    Re: High Salt Levels
    As long as the SWCG is happy and generating chlorine, no, you do not need to drain water.
    You will have some water exchange over time -- you do not show how you are filtering but if you have a sand or DE filter you will backwash. You will also have some splash out, etc. Your current salt reading just means you will not need to add salt for most likely a very long time!
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    According to the manual the intellichlor doesn't report a high salt error until 4500 ppm and even then it will keep making chlorine.
