Thread: Drop in in ground Stairs with 'coved' side to bottom transition
    Apr 2017
    Binghamton
    61
    I am having a very difficult time finding a drop in style set of steps for an inground pool. There are only s few options that I can find and none of them appear to be made to work with the significant curved transition between my walls and floor. It's probably an 18" - 24" transition! At least 12".
    Anybody have this problem before? Any solution? My liner was brand new 2 years ago by the previous owner so putting a legit built in set of steps is out of the question until the liner needs replacing again.
    HELP!
    ~22k gal (36' x16') IG concrete pool with vinyl liner.
    3/4 HP Hayward Pump. Hayward EC75A DE Filter
    Laars Lite 2 Heater. Taylor K-2006 Test Kit
    https://www.facebook.com/domenic.emi...09148469284789
    Binghamton, NY (Upstate)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,890
    Re: Drop in in ground Stairs with 'coved' side to bottom transition
    You know who I would call? Swimming Pool Supplies - Pool Parts - INYOPools.com they are awesome with the out of ordinary stuff like this!
    I am thinking maybe a ladder that does not go all the way down to your bottom??? Just throwing that idea out there.
    Kim
    May 2016
    Troy IL
    484
    My inground vinyl liner pool has wedding cake stairs that were probably made for an above ground pool. Maybe expand your search to include stairs for above ground pools that in in decks? That angle you are talking about may make it a little tougher though.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Apr 2017
    Binghamton
    61
    The above ground stairs all seem to be made for deeper depths than my shallow end.
