Thread: Hayward H200 millivolt.... clarification on operating procedures?
    Jun 2014
    Uxbridge Ontario
    57
    We bought and installed a used Hayward H200 millivolt heater for our 21', 10,000 gallon above ground pool.
    I need some clarification on its operating procedures but couldn't figure it out from the manual.
    Am I supposed to leave the on/off switch in the on position and just turn down the thermostat when we don't need it?
    Or should I turn the switch to the off position as well?
    We do not have any automation, we usually run the pump at night on a timer but I am struggling with how to operate it now that we have the heater.
    We don't intend to use the heater continuously, nor have the pump running all the time.
    Would like to put the pump back on the timer, but obviously don't want it shutting off with the heater still running 😕
    What is the cheapest way to handle this?
    And where should that switch be on the heater? On all the time.... with the thermostat off.
    Off when we are not using it... and then just run the pump and heater manually when we need it?
    And then put the pump on the timer for night time running with out the heater?
    21' x 52" Round Above Ground. (Buried 2') AquaPro 1HP pump, Jacuzzi 19" Sand filter, Hayward inline chlorinator.
    Hayward H200 millivolt NG Heater, SunQuest 2 x 2'x10' Solar heater.
    ps0303's Avatar
    Jul 2011
    FL
    3,931
    Re: Hayward H200 millivolt.... clarification on operating procedures?
    On a milivolt unit, once you light the pilot, it should stay lit all the time. Then you can use the on/off switch to turn it on and off. Thermostat can be in any spot you want. Usually you keep it at your desired temp setting. Then when you want to use the heater, flip the switch to on. As long as the pilot stays lit, you will be ready to use the heater. Just keep in mind that you're burning fuel all the time whether you use it or not.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jun 2014
    Uxbridge Ontario
    57
    Thanks!
    So, if I have the heater on set to temp, and the pump on a timer, would the heater not just turn itself on and off with the pump?
    If I turn them both on together, and then the pump goes off, would it not detect the loss of flow and stop heating?
    That should be some sort of safety feature right?
    If so, does it work the other way too? If the heater is on and set to temp, and then the pump comes on, does it detect the flow and come on?
    Or am I totally off base? Lol!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    if you get one of those intermatic timers with a fireman switch, it will shut off the heater
    10-20 minutes before the pool pump shuts off, to provide adequate cooling / prevent knocking
    in the heater.
    If you heat manually, just make sure the pump runs an additional 5-10 minutes
    after you turn the heater off.
    Dolphin E10 Cleaning Robot.
