Thread: SR Smith pool lights
    Kinglangon63's Avatar
    May 2014
    Ontario,Canada
    41
    Question SR Smith pool lights
    Couple of questions, is it possible to replace light with water in the pool or does it have to be drained. i have 3 lights and 1 of them does not sync in with the other 2. I tried to flip the switch on the timer to get them to sync but no luck, what are the options. I just want the light to be blue but one keeps on changing colours.
    18' x 30' Completely Automated Fox Pool
    2 Pentair Intelliflo VS pumps
    Pentair 250 HD Heater
    Pentair Cartridge Filter & IC 20 Chlorinator
    Intellitouch i10 Automation & Sheer Descent x 3
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: SR Smith pool lights
    Yes, lights are designed to be replaced while the pool is full. There should be enough cord wrapped behind the light to get it to the pool deck to replace.
    May 2014
    Ontario,Canada
    41
    Light was replaced successfully today and is in sync with the other two. apparently the light that did not sync was an older version light.
