Thread: Jandy R8- Program Pool Cleaner to Shut Off When Spa Is On
    May 2017
    bensalem, pa
    1
    Hello,
    I just had to replace my main board on the R8 as it was burned out. I got everything set up but I can't figure out how to shut off the pool cleaner when the spa is running. It used to do this.
    The pool cleaner is Aux 5. As I stated when I used the spa before is would turn off aux 5 which it doesn't do now. Therefore water is emptying out of the spa and going into the pool through the pool cleaner.
    I know it just has to be programmed but I can't figure it out.
    Thanks
    Gary
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Jandy R8- Program Pool Cleaner to Shut Off When Spa Is On
    Welcome to TFP!
    I am not familiar with Jandy automation. But maybe a will help get a response.
