Thread: Pipe repair help
    E Murph's Avatar
    May 2016
    Middletown, Pennsylvania
    47
    Pipe repair help
    Hello. Since switching to this system I no longer use my Hayward chlorinator. It started to leak so I decided to take it out. Sadly I've made a mess of it. There were some holes in the pipe where the fittings went. I cut that section out and replaced a small piece of pipe with a repair coupling but it is leaking. I think I know what I did. I used regular 2" pvc fittings. I believe I should have used a longer fitting? I noticed after I did it that the elbows and joints have different fittings than what I got at lowes? Maybe they are made for pressure and what I have is made for drains? If so where can I buy the correct fittings? Also is the purple primer and pvc cement ok to use? Or do I need something else? I know I will have to cut a bigger section out to remove my bad work.
    Thanks for the help!!!
    15,000gal, IG plaster, DE filter, Centurian 2HP pump, Raypak propane heater, built in 2005, Taylor K-2006 test kit.
    JoyfulNoise's Avatar
    May 2015
    14,094
    Re: Pipe repair help
    All pool plumbing should be Schedule 40 PVC. There is also a thinner walled type of PVC tubing and fittings that is used for Drain/Waste/Vent (DWV) applications; that PVC is not rated for pool use.
    Perhaps if you post some pictures of why you have, some of the plumbing experts can help guide you better.
    Matt
    E Murph's Avatar
    May 2016
    47
    IMG_2134.jpgIMG_2134.jpgIt is schedule 40. Notice how the fittings I used are not as long as original? Is that why it leaks?
    Apr 2016
    NC
    109
    That seems like alot of fittings for what can be a single run. I am also not sure it matters but I know that there is a spa cement it's blue.
    33k IG Gunite, Hayward T-15 Cell SWG, Hayward Sand Filter S210T , Pump Wisper Flo 1.5 HP, Test Kit K-2006
