Thread: Hook up vacuum to an older intex with only 1 intlet and 1 outlet...
    Jul 2016
    Forney, Texas
    9
    Hello, all.
    It is that time of the year again
    I purchased a 18x9x52 Ultra Frame Intex Rectangular pool and it is the "older" style pool before they starting to put the TWO suction outlets and I am having a hard time figuring out how in the world I am supposed to hook my darn vacuum up to it. Last year, we had a newer style pool, and I would just use the hose from the bottom of the skimmer, but I also can't figure out how I am supposed to hook my skimmer up either, since there is only one outlet. I could really use some advice here. If you need any more information, or pictures, let me know! thanks!
    Here is a picture of exactly what our pool looks like, for reference.
    Jun 2015
    Stockholm, Sweden
    261
    Re: Hook up vacuum to an older intex with only 1 intlet and 1 outlet...
    Just connect the vacuum/skimmer to the outlet. Or do what most people here do: install a proper through-the-wall skimmer. Then you can use the outlet as a dedicated vacuum port.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2016
    Forney, Texas
    9
    I found that I needed an adapter...and it worked...but, I did buy a proper through the wall skimmer...just have to figure out how to install it now.
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    it is actually simpler than what you think. i was pretty worried about installing mine, but it was up and going within about 30mins. ask questions, i know i did
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Jun 2015
    Stockholm, Sweden
    261
    There's like a hundred threads on this site showing exactly how it's done. Search for Intex Hayward skimmer
