Thread: Need to replace intex sand filter shell
    May 2017
    Reynoldsburg
    2
    This post was split from Intex: Can I swap out pumps and leave the sand tanks alone?
    @nate81 .... Would your old sand filter tank work with your new system? I ask because we have the discontinued system and need to replace the tank because it cracked. The old tank is no longer available so we were trying to order just the tank as everything else works.
    Jun 2015
    Stockholm, Sweden
    261
    Re: Intex: Can I swap out pumps and leave the sand tanks alone?
    What can be confusing is that they sometimes specify the pump flowrate (higher), sometimes the system flowrate (pump+filter, lower). Your new pump has a 3000 gph flowrate, paired with the filter it has a 2450 gph system flowrate. The latter is the (theoretical) flowrate you can expect, the actual flowrate will be even less due to the plumbing.
    Definitely use the larger filter with the larger pump. Both will work though, they only differ 10 pounds of sand. The sand can be reused as stated above.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    May 2017
    Reynoldsburg
    2
    I'm more curious if all of the attachments are the same and if the new tank will fit in our old stand.
