Thread: Need info on above ground pool steps
    Jun 2016
    Toledo, il
    1
    We've had our pool around 10 years. It is above ground and no deck. I bought some used wedding cake steps for the inside of the pool. Now I need to know what kind of ladder to use on the outside. Our pool is 52 x 18.
    I have an 18 x 54 doughboy above ground pool. We bought it in 2009. We love the pool. It stays clear all summer. All I do after the initial opening is put a chlorine tablet in the holder, I then have it tied so it is right where the water comes into the pool. We have a Hayward pump and filter, 180t.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,884
    Re: Need info on above ground pool steps
    Hi! There are many ideas out there. Here is one I found :
    17 Best ideas about Pool Steps on Pinterest | Swimming pool steps, Swiming pool and Modern pools
    Good luck!
    Kim
