Thread: Itchy spa
    Jun 2016
    Berryville VA
    4
    Itchy spa
    Had this problem last year. Swimming in the pool felt fine. In the spa with temp at 100F , legs felt itchy. Saltwater pool and spa. Unfortunately used test strips so feel my numbers were inaccurate or incomplete. Using test kit this year. Any ideas?
    20k gallon IG pool & spa, pebble, Aquapure PLC1400 SWG
    Jandy DE filter mod # DEV60, Raypak 399k BTU heater
    Jandy pumps, 2.0 hp for pool, 1.5 hp for spa
    Polaris cleaner, 2' sheer descent
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Itchy spa
    Welcome to TFP!
    Most itchy skin spa problems are caused by lack of chlorine allowing bacteria to grow. Bacteria grows much faster in warm spa water than in pools and requires more diligence with maintains FC, including retest after adding to make sure it didn't drop to 0. Also, very high pH and/or TA can be slightly irritating to skin also. TA is best around 50 and pH 7.6 to 7.8.
    More here about balancing water in a hot tub, How do I use Chlorine in my Spa (or pool)?
    I've used this process for quite a few years now and it works great. I also had some trouble with itchy skin early on. Haven't had any problems in many years and we use it almost daily in fall and winter until the pool opens up.
    Jun 2016
    Berryville VA
    4
    Re: Itchy spa
    Thanks for the response. I need some more help though. When my pool is on, water from the spa flows into it through spillway. My current numbers are:
    FC 5
    PH 7.4
    TA 90
    CH 260
    CYA 80
    CC 0
    Salt 3200
    Water temperature 64
    Water tested was from the pool.
    DFW, TX
    24,974
    Re: Itchy spa
    Aha, well that changes things a bit. Those numbers are fine for pH, TA and CH. I would still be inclined to check FC before, during and after when using the spa to see if FC is dropping to 0. Running that temp up to 100 can use up chlorine pretty quickly.
    Jun 2016
    Berryville VA
    4
    Re: Itchy spa
    So I tested my water and got these numbers:
    FC 5
    PH 7.4
    TA 90
    Then I heated the spa to 99. FC and TA were unchanged but PH was up to 8.0
    Any suggestions?
    DFW, TX
    24,974
    Re: Itchy spa
    What is the FC after 30 or 45 minutes uses?
