Thread: Slaming
    Dennis T's Avatar
    Jun 2012
    Columbia, SC
    13
    Slaming
    I did not adjust the PH prior to Slamming. Solution? Thank you
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Slaming
    Quote Originally Posted by Dennis T View Post
    What's the CYA level and the shock level?
    If both are low, and the pool is really green, it shouldn't take long for the FC to drop below 10. When it does, test pH and TA and deal with it.
    If CYA and shock level are high and the water is just murky and already to the grey stage, deal with it afterwards. You don't want to lose momentum.
    Dennis T's Avatar
    Jun 2012
    Columbia, SC
    13
    Re: Slaming
    Clear to the bottom. Somewhat cloudy. CYA 45. FC 20. Thank you
