Results 1 to 13 of 13
Thread: Aqua Rite ECG Control Panel Not Working
    May 2017
    Chicago IL
    6
    Just opened my pool a couple days ago and I can't tell where the problem is. Green power light is lit at all times, Red no flow is full with start up but eventually disappears. None of the other lights come on to indicate check cell, chlorinating, ect. I replaced the fuse and it's the same situation. The box display is stuck on 3000, which is probably the last measurement it was turned off with.
    Could this be a flow switch problem, control panel or cell? Thanks for your assistance in advance.
    I should also state the pool is getting good flow and is above 75 degrees.
    Re: Aqua Rite ECG Control Panel Not Working
    What are the diagnostic readings?
    Support the site
    May 2017
    Chicago IL
    6
    ^ I can check for you, what ones should I be looking at.
    So I took the cell off and cleaned it. Restarted and the control panel came back to life. When I switch it from off to on, generated comes on but check cell flashes and no flow is solid. Eventually they all turn off except power and I'm able to cycle through the diagnostics.
    No display on the LCD?
    Support the site
    May 2017
    Chicago IL
    6
    The display is working now. Before it was stuck on 3000 PPM. I'm thinking the flow switch may be bad.
    Support the site
    May 2017
    Chicago IL
    6
    In order,
    3000
    76
    30.0
    0.00
    39P
    - 0
    AL - 1
    r 1.40
    OK, all of that looks good. If the display stopped working, it could be a loose display board. You can take the display board off and reinstall it to make a better connection.
    If you’re getting a solid No Flow with good flow, it’s probably a bad flow switch. First try unplugging the switch cord from the bottom of the box and reconnecting it.
    Support the site
    May 2017
    Chicago IL
    6
    So last night it appeared the control panel was working and set to generate. I turned it on and today it's reading salt at 1300 from 3000 yesterday?// Put a couple bags in and it's now reading 1400??? What reads the level, cell or flow switch? I'm thinking the cell.
    Move the switch to off. Wait 1 minute. Move the switch to auto. Wait 30 seconds. Recheck all diagnostic readings.
    Make sure that the salt is well mixed in before turning on the system.
    Support the site
    Oct 2015
    San Diego, Ca.
    804
    You might want to get an accurate (Taylor k-1766) test kit.
    You'll want to know, independently from the control panel, what your salt level is.
    The reason is that when the "cell" part goes bad, it frequently starts reading low salt. Some people just keep adding salt hoping it will stop reading "low". When the cell finally quits completely, they are left with 5000 ppm in the pool and the "new" cell won't have any part of that high number. Next thing you know, you are draining the water to get the salt level back to where it was when the "bad" cell indicated "low salt".
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    What are the first 4 of the cell serial number?
    Something like 3E10 etc.
    Support the site
    May 2017
    Chicago IL
    6
    Quote Originally Posted by JamesW View Post
    I've tried that. The cell reads the Salt level, correct?
    Quote Originally Posted by Philo View Post
    Good thinking, I may take both my water and cell in to get checked.
