Thread: New VS Pump for an AG Pool
    My Doughboy Powerline 1.5HP, 12.4 Amp pump is dead and I'm looking at getting a Pentair 342001 Superflo VS https://www.amazon.com/Pentair-34200...peed+pool+pump.
    When I read up on any of these VS pumps, it looks like people are using PVC while my current pump using flex pipe to connect to the pool and filter. Is it a problem if I use flex pipe? Other than attaching power to the unit, is there anything else I'm missing?
    Thanks in advance.
    15,000 gallon AG
    20" Aquaview Sand Filter w/1.5HP pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,243
    Re: New VS Pump for an AG Pool
    C,
    The pump does not care if you use flex pipe or not, unless the water has to travel over long distances..
    As long as you have the adapters to transition from the threaded connection on the pump to your flex pipe, you should be good.
    The water is going about 6'.
    Thanks for the quick response.
    15,000 gallon AG
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Plumb the water in plumb the water out, hook it up to a GFCI power source, connect the bond wire, and program you rpm and run times. Sit back and enjoy the energy savings and quiet operation.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
