Thread: hayward matrix 1.5 hp wont turn on after turning off (new unit)?
    Jun 2016
    Pittsburgh, pa
    369
    I have a newish hayward 1.5 matrix pump.. today i was working on the solar valve actuator.. in testing the actuator while the pump was on, the valve moved to the rightward position (which blocks the flow to the return but allows water to go through the panels and back to the return), in doing so it created bubbles and went a bit nuts.. so i hurried shut the pump off.. figured no harm..
    Well, i fixed the actuator positioning and then tried to turn the pump on.. it wont turn on.. just warm to the touch on the motor housing..
    Any suggestions.. or ideas on what might have happened?
    Thanks in advance
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    40,874
    Re: hayward matrix 1.5 hp wont turn on after turning off (new unit)?
    There is no way the actuator and pump issue are related. You could run the pump dead headed for a few minutes without any issues.
    Check GFCIs and breakers.
    Jun 2016
    Pittsburgh, pa
    369
    Turned out the wiring inside somehow pulled out when we were working around it.. it was a simple enough fix.. tore apart and fixed.. working fine
