Results 1 to 7 of 7
Thread: Filter - replace part or entire filter?
    May 2017
    Ontario, Canada
    28
    Hey all,
    Firstly - thanks everyone for the amazing advice here. I regularly look for information here
    Unfortunately opening this season hasn't gone smoothly...
    I have a Jacuzzi MFM Sand filter (inherited from the previous owners). When I was opening the pool and screwing in the pressure gauge, the plastic housing cracked and the thread appears to be stripped (I guess this can happen with plastic over time). Unfortunately repair attempts have not worked 100% so it has now come down to 2 options:
    1. Replace the part, which unfortunately on this filter is the entire upper housing which also has the handle for the multi port valve. Price range seems to be approx $100 - $150 (canadian).
    2. Buy a new filter entirely. Prices locally seem to be about $400 - $500 (canadian).
    Just looking for any thoughts. No idea on the age of the filter but I think it has been there a while. My worry would be going for option 1, then a different repair next year or the year after and I soon find I may as well have bought the new one. But if that's unlikely, then maybe option 1 is better. I'm also not sure if new filters perform particularly better than older ones...
    Any thoughts would be much appreciated.
    Graham.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Filter - replace part or entire filter?
    I'd go for the repair option. No plumbing headaches that way.
    May 2017
    Ontario, Canada
    28
    Thanks.
    What sort of plumbing headaches would you imagine with a total replacement? While not familiar with the process, I'd imagined reusing the existing pipes. Is that too hopeful?
    Do filters typically last a long while? Like I said, my main concern is spending a reasonable sum of money getting the replacement part, then having to do more repairs. Or is it really only the top part that'd likely break (due to repeated use of the pressure gauge thread and the handle for the multi port) and the rest should all last a long time?
    Wouldn't it be nice if they'd made the housing for the gauge threading metal I'd be temped, even with a replacement part, to add a brass extension anyway so it just stays in and I'm screwing and unscrewing the gauge into metal each year so less likely to strip the thread or crack it in future.
    Thanks!
    Graham.
    Richard320's Avatar
    Jan 2010
    20,299
    Plumbing headaches are just because no two filters have the ports in exactly the same place. So you'll end up cutting and splicing and adding all sorts of elbows and such to get it to connect.
    I have no idea what the lifespan is. And where I live, we hardly ever even see frost. Winterize? What's that?
    May 2017
    Ontario, Canada
    28
    Ah, makes sense - thanks!
    Will be interested to hear if there's any other opinions on which option to pick.
    Thanks!
    Graham.
    JoeGolan's Avatar
    Nov 2016
    Palm Coast, FL
    200
    I'm with Richard on this...
    The filter is not that old and anytime you could avoid redoing the plumbing is a plus
    I'm a black and white type of guy ... the only gray in my life is the hair on my head
    750 gal fiberglass built in spa with Hayward equipment. Pump is SP3010X15AZ Control is Aqua Plus with a T-cell-3 SWG and a H400FD Heater, Hayward C12002 cartridge filter filter
    May 2017
    Ontario, Canada
    28
    Thank you!
    How do you know the age of the filter? Just from the model I gave I'm guessing? Any estimates on age - I've no idea unfortunately.
    Graham.
