Results 1 to 8 of 8
Thread: New Raypak heater install question
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Hi All,
    My new Raypak 106A has arrived. The propane install and hookup is scheduled for Monday. I would like to do all the plumbing today in advance. Is there any issue with running water through before there is gas? It says there is a built in by pass so the plumbing would be pretty basic.
    Any thoughts would be appreciate!
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: New Raypak heater install question
    There is no problem running water through. 100% of the water that passes through my pool pump flows through my heater and has for years whether or not the thing is on or off.
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Thanks Richard!
    First time heater owner so I wanted to be sure. It shows on install that it should be bolted down to a pad? I was planning to just sit on some levelled patio stones. Is bolt down required?
    Cheers!
    Richard320's Avatar
    Jan 2010
    20,296
    That I don't know. I think mine is, but I've never actually looked.
    ps0303's Avatar
    Jul 2011
    FL
    3,919
    Very rarely are they bolted down unless code requires it to be. Then if a homeowner does their own install, they are never bolted down.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Thanks Paul. I think it should be fine. Too bad I don't know how to hook up my 30lb tank to try it out !
    R
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Pool heater is in and running! Ya!!
    Only problem was installer didn't know how to get at the wiring for the fireman switch to hook up my sun touch. I ran wire from the jumper already but alas it's not 100 % complete.
    Anybody know how to remove the control plate to get at the wires?
    R
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    So after first 12 or so hours with new heater this is what I can tell you.
    Ambient temp last night 42° saw a gain of 2-3 °per hour increase with solar blanket on. Turned of pump and heater at 10pm pool went from 57 to 66. This morning at 630 pool was at 63 ambient is 38 pool is now 68 at 830. Solar is not available so is not in use.
    Very impressed so far. Looking forward to seeing how the solar will affect the heater cycles.
    Cheers,
    Rob
