Results 1 to 9 of 9
Thread: Robotic pool vacuum.
    Apr 2017
    Mishawaka/ IN
    11
    Looks like dolphin premier has best rating. Any recomendations, best value for robotic pool vacuum
    Jtwitt - New pool owned
    38x18, sport pool, 25,600 gallons
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    Re: Robotic pool vacuum.
    In ground S200 and twins. Above ground S50 and twins. Not cheap, but value.
    https://www.troublefreepool.com/thre...on-owners-club
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2017
    Mishawaka/ IN
    11
    Well that is 400 cheaper than premier. So, you think it is worth it?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    I'll let you read the Owners thread and decide for yourself. Mine is quite new but satisfaction runs pretty deep among others.
    Feb 2016
    Fort Mill SC
    35
    Quote Originally Posted by bmoreswim View Post
    Does the S50 come with the pleated filter? Have a friend with an AGP looking to buy a robot. I am concerned that that model
    only has the mesh screen.
    Tim
    Tega Cay, SC
    2016 build 16x32 polymer IG-Speck BaduMV 2.4 hp variable speed pump-individually run 2" plumbing-4 returns-1 skimmer-Doheny Discovery robot-
    jetted bench-Pentair Clean and Clear Plus 420 cartridge filter-Circupool RJ60+ SWG-Hotspot FPH heater
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    S50 only has a mesh basket. Though that's all pooldv has ever used on his S200 and he's a big fan.
    https://www.maytronicsus.com/residen...s/s-series/s50
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,261
    jt,
    I have the Dolphin Premier and while it works great for me, I have very few large leaves. I most always use the pleated filters and it keeps my pool spotless. As far as I can tell it does not miss a spot. Of course, like all robots it does not do stairs or seats, at least not all the time.
    The design of the unit does not allow for it to pick up a lot of big leaves as there is just no place for them to go.
    The next robot I buy will be the newer design, with the top loading basket and no handle. Like, or similar to, the Active 30i.
    I have the remote for the Premier , but have never found a reason to use it..
    Thanks for posting,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Quote Originally Posted by Jtwitt View Post
    For your pool, I woukd suggest one of the M Series, or the Oasis Z5. Cant beat em, but they aren't cheap.
    Essential Links:
    Apr 2017
    Mishawaka/ IN
    11
    Thanks all
