Thread: Filter PSI is at O
    Jan 2017
    PALM BEACH GARDENS, FL
    107
    Filter PSI is at O
    My pool is clean all seems to be good, I clean my filters out at least once a month. I just noticed that the PSI is at 0 on my filter gauge. I think it has always been there but not sure, it is now.
    I also notice sometimes in my pump skimmer basket i dont always have water all the way to the top clear lid.
    So, do I need to have water all the way to the top, when i acheive this, will I have PSI on the filter gauge.
    thanks
    GTP
    Pool Size: 17,504 gallons.
    In ground gunnite plaster pool (Florida Gem Stucco)
    Filter Hayward Cartridge C200SHayward Ecostar SP3400VSP variable speed pump.
    Pool Install December 2016 Blue Essence SALT system
    (2) 48" Sheer Descent Waterfalls and (1) bubbler on small deck
    Jan 2017
    107
    Re: Filter PSI is at O
    Update: I now have water all the way to the top of the skimmer at the pump (clear lid) and I up the pump speed a bit, but still only about 3 PSI at filter gauge
    What speed are you using?
    How high is the pressure gauge above the pool water surface?
    Support the site
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,246
    GTP,
    I run at 1,200 RPM most of the time so that my SWCG will work.. At that speed, my filter PSI is about 2 and I have just a few bubbles in the pump lid.
    This is perfectly normal...
    Jan 2017
    107
    I run about 1600 RPM. My gauge is about 4 feet above pool grade
    mas985's Avatar
    Pleasanton, CA
    11,983
    Quote Originally Posted by GreenTerrorPool View Post
    Low RPM = Low PSI. Higher filter height = even lower PSI. So normal for your situation.
    Mark
