Thread: Pool Cleaner Delay
    May 2017
    Houston
    2
    Question Pool Cleaner Delay
    Morning everyone - hope this is in the correct forum. If not, please direct me to the right place.
    I have a Pentair Racer LS run by a Pentair Easy Touch system. For years, I could turn on the cleaner manually, but pressing the cleaner button on the control panel. The pump would start right up.
    Recently, when I push the cleaner button, it blinks red, and I get a DEL message on the screen. Stays this way for 10 or 15 minutes before the pump kicks in and starts running the cleaner.
    Not the end of the world, as I don't manually turn it on very often, just curious why it would start doing this all of the sudden. Any suggestions? Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Cleaner Delay
    Sounds like a delay function has been enabled. Check your user manual for the Easy Touch to see if you can disable a delay. Normally, things like heaters are on a delay or the delay may be enabled to wait for the main pump to run for a while before the booster pump kicks on for the cleaner.
    Isolated Spa - 345 Gallons
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,329
    Cory,
    What Joel said above...
    Under Settings is a delay menu
    or if you have ScreenLogic, just click cancel delays.
