Results 1 to 9 of 9
Thread: would these work as a bottom mat?
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Someone local is selling these rubber interlocking flooring mats for $2.00 a mat. I found what appears to be the same item on Amazon and it says indoor and outdoor use. Could these be used on the pool floor to cushion the liner? I don't want a moldy mess under there.
    https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    Re: would these work as a bottom mat?
    this is what i have under our pool and everybody loves the feel. nice and soft and does not leave footprints. almost the same price as what those you are looking at. those you posted are the ones you see in the gym that does not have much give. i actually think they make those weight lifting pads the same as they do tires with the steel in them.
    Anti-Fatigue Foam Mat Set 4 Pc
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    May 2017
    Dacula/ga
    2
    I just installed the mats from harbor freight. The are great. You can catch them on sale for $6.99 for 4 pcs
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Yes, they are technically gym mats. They are made from rubber which I thought may stand up to being buried. We live in a rocky area and I am concerned about rocks making there way up to the bottom of the pool.
    chayne's Avatar
    May 2016
    419
    yes, i really like the way the mats feel under the liner.
    Charles
    Coleman 16'x48"
    Townlakecakes's Avatar
    Aug 2016
    Sugar Land, TX
    6
    We used them too. I kind of wish we had taped them together. All the sediment in the pool settles into the grooves in between, although I've never had a problem vacuuming it out. They do feel very good underfoot.
    "Free" 15'x 36" Intex Easy Set pool (2015)
    Intex ECO8110 SWG (2015)
    3000 gph Intex sand filter (2016)
    Intex floating skimmer, Intex automatic vacuum, Taylor FAS-DPD test kit (of course)
    chayne's Avatar
    May 2016
    419
    i wished i had put down 2 layers of tape over the grooves. i have sediment that gets into the grooves too even though it was taped.
    Charles
    Coleman 16'x48"
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    I think I am just going to stick with the one piece floor pad. I don't want to have groves from all the joints.
    33' x 18' x 54" Saltwater 8000 above ground pool (14k gallons) / AquaPro 190 SQ. FT. Cartridge Filter 2-HP 2-Speed Pump / Circupool SJ-40 Salt Generator (for 40k gallons)/ TF-100 test kit
    Photos of my build!
    chayne's Avatar
    May 2016
    419
    i dont think you would have the grooves if you were to put 2 layers of tape instead of the 1 that i did. either way i am sure you will enjoy the nice soft pool bottom.
    Charles
    Coleman 16'x48"
