So main pump and SWG are wired together on Intellitouch, which current schedule is set to ON for 24/7, powering both devices.
Pumps current internal schedule is to also set to run 24/7 at various speeds, which seems to be somewhat overkill.
If I change/lower run time of pump, Intellichlor with still be power and go to low flow, is that a issue?
Should I set a separate aux relay and piggy back it off main for pump and create a second schedule for Intellichlor inside of the pump run times?
Then I would not need to worry about the no flow and SWG always being powered.
After some reading it appears that people have the pump and SWG set to run during they day.
Which makes sense if most of the Chlorine is lost during the day, seems to be the easiest way to keep things balanced.
Am I on the right track?
Hope this is in correct section to post. Have tried multiple searches on subject with no luck.
