Thread: Vinyl liner trouble
    May 2017
    Faribault, MN
    1
    Vinyl liner trouble
    Trying to start pool up for the first time ever, new home, liner suddenly has wrinkles. Following on line suggestions to lightly tap them out, we either found or produced a tear. Everything says do not drain, but how can we fix a liner tear that is ON a wrinkle? TIA for any help
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    686
    Re: Vinyl liner trouble
    How long or big is the wrinkle? Also do you know how old the liner is? If it is brittle enough to tear then it might be that it is just time for a new one. But if that won't do than it'd be best to be able to patch over the entire area but if the wrinkle is extremely long or it isn't possible to apply a patch over the whole area than I'm not entirely sure myself on the best way to go about patching it. You don't have to drain to patch as the patch kits are designed to be done underwater. The question is though is what is the size and area of coverage that is needing to be patched.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    photo if possible would help.
    Dolphin E10 Cleaning Robot.
