Thread: tri sodium phosphate question
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    tri sodium phosphate, is this the stuff I would use to clean the pleated filters on my Dolphin vacuum? The packaging at Lowes says this is for cleaning of decks and vinyl siding. Just want to make sure I am getting the right stuff?? Thanks!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    JoyfulNoise's Avatar
    May 2015
    14,077
    Re: tri sodium phosphate question
    Yep. Just mix it at the rate on the side of the box. It's usually about 1/4 cup per gallon of water or so. For organic fouling that may have left stains, you can also add about 1 pint of bleach per gallon of water. Best method is to get a plastic garbage can line it with a thick outdoor trash bag and then mix up the solution in that. Then submerge the filters in the can. Depending on what might be on the filter, you may have to soak it for a while. After soaking, pull the filter and rinse it well with the hose. Careful with the backsplash and wear eye protection and old clothes. The used solution can just be dumped in an area of the yard no one cares about...I wouldn't dump it out on the lawn or else you'll kill the grass. It can down the drain too but it's usually too difficult to pour from a can like that.
    Matt
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Thanks for the quick reply, Matt. Good advice, but my filters (4) are only about 11x4"s, so do I need to go to that much extremes? I clean my filters as soon as the vac comes out of the pool, they are just getting a brown stained look to them, and I would like to catch it before it gets worse. Again.......thanks!!
    Mark
    May 2015
    14,077
    Whatever works best. Usually you'll need to soak the filters for a while, so whatever container you have that works is best. The cartridges inside my DE filter are about 36" tall by 4" in diameter, so a trash can method works best for my tall filters.
    Just note - TSP and aluminum is a bad combo! The TSP is caustic and will pit and corrode any kind of aluminum....so dispose of it safely.
    Matt
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Got it!! I will probably just use a 5 gallon bucket or cat litter container this evening! Thank you!
    Mark
