Thread: Change size of holes in above ground soft pool
    Jun 2016
    Asheville nc
    20
    Hey,
    i had a 18' intex round inflatable easy set ring pool last year. The mice got into it over the winter and I ordered another 18' intex round inflatable easy set pool. The holes in this pool are smaller than last year's for the intake and outlet for the water. Can I cut them to fit my fittings? If so, to what size, exactly?
    do I need to replace my fittings with smaller ones? If so, where do I buy them?
    thanks!!
    18x48 intex AG, 2650 Intex sand filter and salt system, I think around 5500 gallons
    40,879
    Re: Change size of holes in above ground soft pool
    Will the vinyl not stretch over your existing fittings?
    Jun 2016
    Asheville nc
    20
    No, the holes are the size of the smaller fittings that I had on my older 16' pool. My pool and pump
    from last year have larger pipes and fittings.
