Results 1 to 9 of 9
Thread: Solar covers vs solar panels
    May 2016
    Effingham, IL
    92
    I am needing a new solar cover and was wondering if you prefer the covers or solar heating panels. If you prefer the covers is there a big difference between grades of covers?
    Thanks
    Kelly P
    Above Ground, 18x40 Oval, 19500 gallons, Sand Filter, Liquid Chlorine
    Kelly
    40,893
    Re: Solar covers vs solar panels
    Covers hold heat in the water by reducing losses to evaporation.
    Panels add heat by capturing it from the sun.
    2 totally separate mechanisms.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    I'd PREFER to have both.......but I just bought my first solar cover earlier this week. Common consensus here is that there is no relative difference between performance or longevity between 5 to 16 mil. blue or clear or the mixture of the two. The cheapest 8 mil you can find is my recommendation. The covers mostly shine in maintaining temps you have rather than adding to them. I haven't had any warmer ambient air temps than the pool temp since I put mine on, at least long enough to matter.....but I'm waiting to see!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    + 1 To what was already said.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    +1 to the +1
    The first step is always to add a solar cover, 8 mil, thin and cheap. It may do all you need. It will add 2 or 3 degrees to the pool most days by reducing the overnight heat loss. Over time it will tend to keep your pool at the high temp rather than the midpoint between low and high. Solar panels will add heat to the pool. Our pool has been 88-89 for the last couple of weeks with a good high 80 and avg low 60. This mostly with solar panels and a solar cover and a little boost from the heat pump during cold fronts or rain.
    May 2016
    Effingham, IL
    92
    Do you know if the aquapill solarlpill or liquid solar works or stick with a solar cover?
    Kelly
    40,893
    Doesn't work if there is any breeze. Many threads discussing it.
    BasicTek's Avatar
    Oct 2016
    Lake Mary, FL
    775
    I prefer both as stated earlier but the costs for solar panels are much more than any cover. I'm looking to keep a consistently high temp of 90 year round in florida. As stated the solar panels add heat, the cover retains it especially overnight and during the cooler days. The cover will also create a cumulative effect (the longer it's on the more heat will be saved) and it is also great to prevent evaporation. I had no interest in liquid alternative based on the reviews and I really don't want to pour anything like that into my pool.
    -Tim-
    Pool: 86 gunite/plaster screened IG 12K 14' X 29', Hayward 120 sq ft cartridge filter, Pentair Intelliflo 2 VST, Hayward SwimPure 40K SWCG, Hayward Poolvergnuegen autovac,
    Heat: 280 sq ft Ultrasun solar Panels, Pentair Solartouch Ctrl, (solar cover and reel)
    Tests: Taylor K-2006C & K-1766 w/ speedstir
    May 2016
    Effingham, IL
    92
    Thank you!!!!!
    Kelly
