Results 1 to 9 of 9
Thread: Best Way To Raise PH without Raising Alkalinity
    May 2015
    Chardon, ohio
    22
    I am getting ready to flock my in-ground pool to vacuum to waste all the dead algea after an algea bloom. Alkalinity is 95 and PH is 7.2. Bottle of flock recommends PH to be 7.8 or above for it to work as advertised and I don't know why. Should I try to raise the PH up? How do I raise it up without messing too much with alkalinity? Any pointers from you experts to this novice would be greatly appreciated.
    Thanks
    22000 Gallon in ground vinyl pool built in 2000, sanitized with chlorine
    Hayward C900 Cartridge Filter, Hayward Super Pump, 1HP, Single Speed
    Taylor test kit
    I have well water and do not use it in my pool. Have water trucked in when I need it.
    I live in the Cleveland, Ohio area
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Best Way To Raise PH without Raising Alkalinity
    to raise Ph without effecting TA-----------aeration of the surface.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Aerate the water. If you have a spa, crank it up to max and turn on the blower. If not, point the return eyeballs up to get the surface rippling. People have devised all sorts of things with PVC pipe. Someone else used a submersible pump hooked to a lawn sprinkler.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    I made this aerator from PVC from Home Depot and hooked it up to my Polaris booster pump port in the pool wall.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    Jun 2016
    Walhalla, SC
    275
    Quote Originally Posted by DeanP66 View Post
    What kind of fitting did you use to connect that up to the Polaris port? I'm interested in doing something like this. Did you use dry fit, or PVC glue? Looks nice and perhaps good for targeting flow to a skimmer.
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    My pool port is a threaded 3/4 pipe, so I just bought a 3/4" to 1" adapter at Home Depot and built everything with 1" pvc. I did use a few unions to make it easier to assemble and disassemble when needed. I glued everything together. I orginally started with just a single one, but decided to add a second one to see if it would decrease the aeration time needed. Not sure how much it really helped. Even just one would work fine IMO.
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Here was my original build. It actually generated more intense bubbles more than likely because it was only a single unit instead of two.
    Jun 2016
    Walhalla, SC
    275
    Thanks! I like all the unions. I've seen other options but I like this one for the circulation potential - I don't get great circulation in the deep end, so this gives me a way to do surface and middle of the deep end at the same time. My port has the quick disconnect (https://www.amazon.com/dp/B003ZTUEAO), so I've been trying to think of a way to fit this connection into an aeration tool. I'll eventually get there!
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    The quick disconnect is 1.5" I believe, so you could just get a 1.5" threaded piece and use all 1.5" pvc. I try not use it unless I really need to aerate because it can get costly running off my booster pump for long periods.
