So everything I do is per instructions, but instead of letting the water spill over the top of the filter, I bring the water to the brim of the stand pipe, and then shop vac the water out. I repeated this three times. The reason is the sand filter is inside out shed...
Is three times enough? Water still had some **** in it (i didn't vac too close to top of sand), and following this, vac to waste, then backwash, then rinse, then normal filter operation.
Thoughts?
18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
Thoughts?
