Thread: Alternative approach to deep cleaning sand filter
    Jun 2015
    Ottawa/Ontario
    357
    So everything I do is per instructions, but instead of letting the water spill over the top of the filter, I bring the water to the brim of the stand pipe, and then shop vac the water out. I repeated this three times. The reason is the sand filter is inside out shed...
    Is three times enough? Water still had some **** in it (i didn't vac too close to top of sand), and following this, vac to waste, then backwash, then rinse, then normal filter operation.
    Thoughts?
    18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    40,895
    Re: Alternative approach to deep cleaning sand filter
    It sure does not sound like enough to me. I seem to recall where members do this and they are overflowing the filter for a long time and still seeing debris come out.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    I seriously doubt 3 times barely even phased it. Did mine after 5 years of operation and let it overflow for at least an hour and a half or so. That's while gently poking the hose around on low flow.
    Jun 2015
    Ottawa/Ontario
    357
    Wow! Ok. Good to know. Back to the drawing board!! Thanks both.
    Apr 2010
    East Texas
    10,158
    Deep cleaning of sand filter----another testimony.
