Thread: Foamy Water??
    Jul 2007
    Louisville
    21
    Foamy Water??
    I opened our pool on Sunday, it was the worst green swamp it's ever been. I put three bags of shock and the next day it was a foamy mess. I'm not a big numbers person, but according to the strip I use, everything is good, except calcium hardness is low. I added no algaecide. This is only from shock. The pool store seems to think I have an air leak. Could this be the case. The foam is getting better--slowly. Here are some pics. First one is right after taking off cover Sunday and last one today.
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: Foamy Water??
    Not unusual to see that when algae is dying. Check out the pictures in A little encouragement for those with algae and new to BBB
    I find it hard to believe that after 10 years as a member here you're still using test strips.
    Jul 2007
    Louisville
    21
    Re: Foamy Water??
    Hanging my head in shame. Yes, guilty as charged.
    c ya, grivera
    40,848
    Re: Foamy Water??
    And still visiting the pool store and taking their advice ... tisk tisk tisk
    You need to be following the slam process and not just dumping random amounts of shock powder in.
