Thread: New liner after 5 years non-use
    Apr 2016
    Baton Rouge, Louisiana
    7
    Morning, had a new vinyl pool liner placed after about 5 years of just having pool covered, and also had sand replaced in filter. Water finally filled pool to skimmer 2 days ago(Wednesday) and turned on pump and "mud" came out of jets for about 20-30 seconds. I used enough cya to raise it to 40 per pool calculator. (Did it the wrong way and placed it directly in skimmer, read about that part too late!)added 2.5 gallons 10% liquid chlorine & next morning(Thursday) Fc =10.5, cc0.5, ph 7.8, added about 1 gallon chlorine, rechecked this morning (Friday) fc 17, cc0.5, ph 8.0, ta 190. Pump has been running 24/7 since. Pool is pretty clear, I can see bottom of deep end, but what appears to be sand is at bottom and I brush pool it becomes cloudy again. Do I just need to brush more? Do not have robot or automatic cleaner yet. Any help is appreciated.
    Baton Rouge, Louisiana. Kidney shaped inground vinyl pool 14x36, approximately 20,700 gallons. Hayward 24" sand filter with Century Centurion 1hp pump, also has booster pump but can not read label.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: New liner after 5 years non-use
    What you need is a manual vacuum to pick that stuff up so it can be filtered out.
    You'll need a vacuum plate, a hose, a pole, and a vinyl pool vacuum head. Pictures of all can be found here: Pool School - Visual Encyclopedia of Pool Equipment
    Apr 2016
    7
    Thanks for the quick reply, guess I was overthinking that one.
