Thread: GL235 Solar Controller Not Shutting Off Actuator in Auto Mode
    May 2017
    tampa florida
    2
    Thanks in advance for any assistance:
    Using ON and OFF the actuator works fine. Assuming the problem is with the solar sensor. Following the manual's troubleshooting guide I disconnected the sensor and the HEATING light went off correctly and turned back on when I reconnected. My concern is that the CHECK SENSOR light never came on at all with the sensor disconnected. Should I try a new sensor or does it sound like a board issue?
    PebbleTech 12,000 gallon
    GL-235 Solar Controller
    GVA-24V Valve Actuator
    Naturesoft Electronic Chlorine Generator (Goldline)
    Hayward Super II 1.5 HP Pump
    40,848
    Re: GL235 Solar Controller Not Shutting Off Actuator in Auto Mode
    Does that controller report sensed solar temperature and pool water temperature?
    May 2017
    tampa florida
    2
    No. It does not.
