Results 1 to 12 of 12
Thread: Thanks and calcium ?
    May 2017
    Chapin, SC
    10
    Thanks for all the info on this site. I have taken care of my pool on my own for a few years with only some issues. The more I read here the better my pool looks. I have a plaster pool, SWG, cartridge filter, 22,000 gallons.
    My question to start is, I don't see on any other site about keeping calcium levels between 350 and 450 for a SWG pool. I have a few, white, very hard protruding deposits on the side of my pool. I am guessing the calcium levels of 250 my be causing this so I am raising it to 350 now. Hope I am doing the right thing!
    30,963
    Re: Thanks and calcium ?
    No. Leave your CH alone. A pic would help but you are probably seeing calcium nodules. Calcium Nodules in pools
    Your CH is fine and will rise on it's own anyway so don't mess with it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Welcome!
    What those things are is explained very well here: Calcium Nodules in pools
    May 2017
    Chapin, SC
    10
    Oops, already messed with it due the levels recommended in the ABC's of pool chemistry where it list calcium levels for a SWG pool as 350 - 450. So I am a little confused. I am up to 350 this am. Soooooo, do I leave it alone at 350 or go to the trouble of trying to lower it back down.
    The second picture is exactly what mine looks like, thanks for that.
    Richard320's Avatar
    Jan 2010
    20,312
    Leave it where it is. As water evaporates, the CH stays behind and builds. It'll just continue to climb as the summer goes on.
    30,963
    Leave it alone. Where in pool school did you find minimum CH as 350 ppm?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    CH of 350-450 is recommended for SWG and plaster here, Pool School - Recommended Levels and here, Pool School - Water Balance for SWGs
    May 2017
    Chapin, SC
    10
    Quote Originally Posted by pooldv View Post
    So pool school says 350-450, but some here say don't go that high. I am now conflicted with what my calcium levels should be?
    DFW, TX
    24,974
    The reason folks are hesitant to recommend increasing CH in a pool is because some areas, especially the southwest, have high CH in their tap water. And since calcium stays in the pool while the water evaporates the CH is constantly increasing over time.
    So, for your pool the question would be what is the CH of your fill water? If you have soft water you will want to increase CH and if you have hard water you might not want to. It isn't a huge deal either way really. It is fairly easy to manage a pool with a very wide range of CH. We have folks who manage pools with CH above 1000.
    May 2017
    Chapin, SC
    10
    Ok, I will test my fill water so I will know where I stand with that. Thanks for your help.
    May 2017
    Chapin, SC
    10
    Quote Originally Posted by Kgm View Post
    Checked my fill water, it is 30.
    DFW, TX
    24,974
    Wow, that is really low. Raising you CH was the right answer in your case.
