Thread: Bleach Weights/Strengths
    Camp Pool Guy's Avatar
    Oct 2016
    New Milford
    12
    Morning all
    I'm a little confused (and part of it is first thing in the morning)
    I opened my pool using pool math and Clorox Concentrated -- but -- I get a VERY good price on bleach from our Janitorial supply company (5g bucket with pump measure) but even though I have the MDS for it, I am either drawing a blank on coming up with the weight/trade or having a hiccough of the brains). My rep tells me it is stronger/more-concentrated than clorox so I can use less (albeit he thinks sanitizing laundry etc.) but this isn't my wash.
    here's a link to the MDS http://pariserchem.com/files/STAINEX.pdf ... it says "A highly concentrated, 15% stabilized liquid chlorine type bleach." --can anyone give me some guideance?
    Thanks in advance
    Richard
    InGround,30x50, 50,000G, PVC on Concrete
    Tandem Filtration 2 x Hayward 2HP Superpump
    1 x Hayward S270T -- Fiber Clear Enhanced 1 x Pentair NSF72 DE -- Fiber Clear Media Used
    Lars Jandy XL3 Oil Fired Heater 1 x Hayward Booster Pump on Home-Grown Solar Heater (which does the job)
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Re: Bleach Weights/Strengths
    I am not sure if that is bleach reading the pamphlet. From what I understand you will want to use straight bleach and that is instable so you will want to know how it is stabilized and make sure that you are not added some random extra chemicals to your pool. On the container it should have ingredients listed similar to this. Shoot a picture of that
    20x40 40k vinyl pool, hayward pro series S220t sand filter with vacuum pump and pentair model 320 in line feeder. No clue as to what type of skimmers I have. Just got my k-2006 test kit.
    30,950
    It is probably just fine for pool use but you need to be in touch with the manufacturer to find the strength and make sure it contains NO other additives.
    15% bleach would be quite rare and would have to be very fresh to retain that percentage. I have understood that some producers provide 12% labeled bleach but they produce it at 15% so it will arrive at the end user around 12%. Even then, 12% depletes rather quickly. 10% is MUCH more stable and is cxommonly available for pool use.
    Oct 2016
    New Milford
    12
    The 5g bucket does not appear to have this label...that is what I looked for first.
    The SDS appears that there is no "additives" either. It looks like it varies (decays) up down to 7% as something said 7-15%
    Richard
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The document you provided is not an SDS, just a product information sheet. This is the only SDS I could find in a quick online search. http://www.packagesupply.net/private...er/stainex.pdf
    It doesn't look like there are any other ingredients aside from hypochlorite. The concentration is not specified on the SDS. There are methods for determining the concentration directly but I would simply dose your pool using Pool Math and the 15% in the % box. Test your pool for FC prior to adding and after 30 minutes of circulation. Adjust from there. Percentages above 10% decay fairly quickly so production dates on the containers are more critical to get the value for your money. I always get the freshest available when I buy my 12.5% and try to only have up to a months supply on hand so that I can buy fresher supply. Where I get mine it's so cheap I don't worry about it too much but might as well get the value that's available.
    Isolated Spa - 345 Gallons
    Oct 2016
    New Milford
    12
    Quote Originally Posted by JVTrain View Post
    This is the advice I took (thank you all) and besides one post rainy weekend (I actually pumped about 3K gallons to waste to get my skimmers back) it's mostly held pretty well.
    Richard
