Thread: Draining pool/Vacuuming to waste
    Apr 2017
    San Ramon, Ca
    7
    Still figuring out my pool equipment.
    If I wanted to drain my pool/vacuum to waste I would just need to attach a hose to the faucet and run it out to the street?
    I just filled my pool to raise it up to half the skimmer opening a few days ago. Now it's down again a half inch. Is that normal? It has not been to hot in the SF Bay Area at all this week. I am sure that there is some sort of a drain that doesn't allow your pool to overflow. If yes where would I find that?
    Thanks for any advice.
    ~26k Gallons, Plaster,in ground installed 2001, Purex/Triton Ultra Flo 6147 2HP Filter Pump, Pentair CCP 420 Filter, Compool LX220 Solar controller, 11 Panel Solar Industries Solar Panel, Lytro Legend Sweeper, Taylor K-2600 test kit.
    40,848
    Re: Draining pool/Vacuuming to waste
    That is not really there to allow vacuum to waste, most of the water would still go into your filter. It can be used to drain off a little water though.
    Not all pools have overflow drains. My 2 have not.
    Apr 2017
    San Ramon, Ca
    7
    So how would I go about draining my pool? I want to lower my CYA since it is over a 100. Could I use the faucet to drain the pool a little at a time add more water then drain it again? Or Should I just buy a submersible pump and pump out the water?
    Aug 2016
    Warminster, PA
    36
    i'd use a submersible pump and a hose.
    Viking Coronado IG Fiberglass 13k gallons, Pentair Intelliflo VS Pump, Pentair Cartridge Filter (320 sqft), Pentair Electric Heat Pump (125k btu), Pentair Intellichlor IC20 SWG. TF-100 Test Kit. Located in SouthEastern PA.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    J,
    I agree with sandman, the best way is to buy, or rent, a submersible pump. Using your pool pump can become difficult unless you have a way to turn off the skimmer(s) and select just the main drain.
    40,848
    I rent a pump from Home Depot when I need to.
