Thread: Pentair Intelliflo 011018 start issues
    May 2015
    Bloomfield, MI
    3
    Just opened pool for second season, and I cannot get pump to turn on. This pump is connected to an EasyTouch Control Panel. With panel in Service Mode, and Pump circuit on, pump control panel is on. Controls appear to function normal, when I choose a speed and push 'start', the display shows the RPMs ramp up and pump enter priming mode but motor never starts. Signal cable is connected. I have turned power on and off to panel to reset everything, but can't get it to turn on. Any suggestions?
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    Re: Pentair Intelliflo 011018 start issues
    Service Mode disables the pump - for Service.
    Try turning off the service mode.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    May 2015
    Bloomfield, MI
    3
    It does the same thing whether in Auto or Service mode on the panel, and pump has always run when panel is in Service mode (it is how I typically backwash), just allows control manually on the pump itself, instead of through the EasyTouch.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    R,
    Sorry, but I can't thing of a thing that you can do that would fix your issue. If the controller "thinks" it is telling the pump to run and the pump is not, then that sounds like an issue inside the pump itself.
    Since this is just the 2nd season, I have to assume the pump is still under warranty, if so, I'd ask your pool builder to send out a Pentair warranty tech.
    You could also call Pentair tech support and see what they say... If you do, and they have some other advice, please post here so we can all learn.
