Results 1 to 9 of 9
Thread: Intex 7k gallon Salt water generator connections leaking, pvc? Replacement washers?
    Jun 2016
    Pittsburgh, pa
    369
    Im having an issue.. i cant stop the connectors from leaking.. i've used teflon tape on both.. found a pvc connector that matched threads.. i think in the pvc case its odd mismatch in threading and probably needs removed.
    I did do the carlon box adapter trick prior to the pvc one.. though it leaked too.. i think mainly because i didnt sand off the lettering on it.. i may retry that one.
    For the regular nut.. not sure why its leaking, maybe needs new teflon, it hasnt been an issue in the past.. either way i'm redoing the pvc one because i should have a union just after it (it goes to 2" pipe).. with the carlon ill go to a 1.5 coupler, then a bushing that goes to 2.0 pvc
    Any suggestions?
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,753
    Re: Intex 7k gallon Salt water generator connections leaking, both with pvc and origi
    The threading on the PVC collars is different than that on the Intex connectors, causing them to bind up before they screw down tight enough to seal off the connection. You can add a 2nd rubber washer and it'll work. I've done this with several connections on my pool.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by jeffchap View Post
    Thanks.. This is what i figured/was afraid of.. where do you get the washers at if you dont already have them.. i couldnt find any when i looked before at lowes.. or what type of washer would it be.. Also.. i just stumbled onto this.. i may switch to this too, then i dont need to cut the pipe and put a union in (i guess either will work if the washers do, but i still think i need a washer either way).. INTEX transition to PVC - YouTube
    basically its this lowes part which is Item # 22654 Model # PVC 00111 0800 "Charlotte Pipe 1-1/2-in dia PVC Fitting Adapter Fitting".. you just put this into a 1.5" coupler.. then cut it right after the threads with a miter saw.. then sand the rough edges.. then glue it with the nut on it and coupler and go from there, along with the washer. I need to convert the other side to pvc anyway, since there is still a hose, which is bent at a bad angle i think, causing an increase in psi.. so i may try this at least on that side and compare results.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,753
    Ace Hardware
    Pentair IC40 SWG
    Jun 2016
    Pittsburgh, pa
    369
    Ace Hardware
    Wow thanks, just what i needed and ace is right next door too Thank you
    Jun 2016
    Pittsburgh, pa
    369
    Ace Hardware
    Update, i tried ace hardware.. they were clueless.. they tried looking up the UPC code and nothing came up.. i looked online on their site and i cant find anything.. closest i see is this on amazon for $17 (crazy).. and the picture at least, doesnt look right to me
    I'm seeing a few on amazon but not sure any of them are right.. like this one that says "stepped", but i thought the original was flat or this, but it looks to large
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,753
    Re: Intex 7k gallon Salt water generator connections leaking, pvc? Replacement washer
    You just need something about 1/8 inch thick that fits inside the collar. If the hole in the middle is too small, l cut it out larger with an Xacto knife.
    If you have any extras of the Intex washers, you can stack a couple of them too. I've had so many Intex pools and pumps, I've always got some lying around.
    Pentair IC40 SWG
    jmcdtucson's Avatar
    Jun 2014
    332
    The box adapter works perfectly, but I think you do have to sand off the lettering (I always do).
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by jmcdtucson View Post
    Yep the adapter from lowes worked like a treat.. just used the miter saw to cut it, then a flat sander + washer.. all good.. no more leaks
