Thread: How long until I swim?
    Apr 2015
    Allen
    61
    So out of curiosity, after my pool is filled with water, when can I swim?
    Dig 4/12/17, Gunite 4/19/17, Deck Installed 5/2/17, Plaster 6/12/17
    13,000 gallon, 24 x 19 rectangular pool/spa, platinum quartz plaster, travertine deck with raised beam in sloped yard. Polaris 3900 Complete, Jandy vsp 2.7hp, Jandy JX1400 Natural Heater, Jandy PDA PS6 (Pool/Spa), TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: How long until I swim?
    What did the builder say? You don't want to give him any excuse to weasel out of the warranty. Personally, I'd wait until you don't get any more dust off the walls when you brush, at least.
    It should go without saying that you want pH in range, FC adequate for the CYA, and clear enough to see the main drain.
    Killer95Stang's Avatar
    Sunny SoCal
    695
    Brand new pool.. jump in as soon as the water hits the top. You do take a shower with same fill water? Ever swim in a lake without the proper ph, cya or fc level? Seriously, if you have kids, nobody will die if you do a lap or two the next day.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Hey_Zeus's Avatar
    Mar 2017
    Orlando
    48
    Quote Originally Posted by Killer95Stang View Post
    I am absolutely going to do that for my pool. Have a pool party? No. But get in 15 mins after it hits wall tile, yep!
    DIY 19,000 Gallon, free form Gunite, Pentair VS 3HP, IC40 Salt System, Pentair Clean and Clear Cartridge 420 sq ft
