Results 1 to 7 of 7
Thread: Plaster discoloration after ascorbic acid stain removal
    May 2017
    Folsom/CA
    3
    Question Plaster discoloration after ascorbic acid stain removal
    Vitamin C tablets removed stains caused by a chlorine puck, but left a different discoloration that I would like to get rid of (picture attached). The pool is currently dry and the problem areas are barely noticeable when dry. Does anyone have any ideas on how to remove the discoloration?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,916
    Re: Plaster discoloration after ascorbic acid stain removal
    What have you tried? I would try bleach and muriatic acid cut 1 to 4 (m.a. 1 to water 4).
    Good luck!
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    More here about pool stains, Pool School - Pool Stains
    Please add your pool info to your signature so that we can help you. More here about what to put in your signature, Pool School - Read This BEFORE You Post
    Why is the pool empty?
    May 2017
    Folsom/CA
    3
    I'm relatively new to pools (1.5 yrs) and did not want to try anything without seeking advice to avoid making the spots look worse. Pool turned to a swamp when I was away from home for an extended period, so I drained and cleaned it, and it is now waiting to be refilled, pending anything I might do for the spots. FYI, there had to be some copper in the water from many bottles of Clorox xtra blue shock that I had used fighting algae (no longer doing this), so maybe this contributed to the discoloration.
    Is there any problem leaving the pool dry for up to a couple weeks while I sort this out? Temperature forecast is in low 70s.
    20K gal, IG plaster (10+ years old), 1.5HP Hayward Super II pump, 175 sqft cartridge filter, Polaris 280 w/ 3/4 HP Hayward 5060 Booster Pump
    30,942
    I think you would do better to get water back in the pool rather quickly. I am not sure you can get all those stains, although some may be organic and will slowly fade if you keep your water chlorinated adequately.
    DFW, TX
    24,974
    Agreed, I would fill the pool back up. It is not good for pools or plaster to be empty for any period of time. Everything we recommend for clearing stains or algae can be accomplished with the pool full of water. Even if it is a swamp.
    May 2017
    Folsom/CA
    3
    Thanks, I'll start filling right away.
