Results 1 to 7 of 7
Thread: Sand from filter?
    Jul 2016
    OK
    19
    Sand from filter?
    I am having issues with sand getting into the pool from my filter, is there anything i can attach to the return jet that captures the sand?I have seen something called the slimbag and was curious if there has been anyone using it. Thanks in advance!
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Re: Sand from filter?
    It's not normal, and indicates the laterals could be cracked or assembled incorrectly inside the filter.
    Did you just deep clean it, or has this been an ongoing problem?
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Jul 2016
    OK
    19
    The sand filter and pump i bought last year and put the laterals down slowly put the sand in by hand have had this issue since. When i asked the pool store they said it could be the finer particulates passing and should stop. But I will keep an eye on it more now because i got it late last year and didnt get to get in the pool much.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    A hole-less sock and a rubber band on the return jets should catch the stuff.
    If you get rid of it and it stops, the pool store was right. If it doesn;t stop, you're going to have to empty it and inspect things.
    Jul 2016
    OK
    19
    Sand Filter Problems - Page 4
    Looks like im not the only one having issues!
    Jul 2016
    OK
    19
    Here a couple pics from the link i shared. From what I can remember this is what they looked like
    Oct 2016
    Phoenix
    203
    Did you use pool filter sand?? I didn't read the other thread fully but the photos you re-posted look like play sand was used, not pool filter sand. I've never had issues with the Quickrete Pool Filter sand from Home Depot or Lowes.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
