Thread: Is it safe to dig 1 feet deep hole on the cement where pool equipment sits?
    Jun 2016
    San Jose
    30
    Hi I want to replace the old fence surrounding the pool equipment to block them from visual.
    The fence guy asks if they can drill one foot deep hole on the cement, as shown in the photo below, to drop fence posts. I wonder if it would break any plumbing.
    My pool guy says should be fine but I'd better check at different sources to make sure it's fine, otherwise it'd be a critical problem.
    20 year old 12k Gal IG pool with SPA, Concrete white plaster, 1.0HP pump, Cartrige filter
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,329
    Re: Is it safe to dig 1 feet deep hole on the cement where pool equipment sits?
    Eric,
    I doubt there is any plumbing inside the concrete, but no telling what is under the concrete.
    I would cut out just the concrete and then start digging by hand below that point.
    Although I'm not sure how useful it will be only going down only one foot..
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    That picture is incomplete.
    Which way is the pool from there?
    Which way to the gas meter from the heater gas pipe?
    Where's the electrical?
    You could end up hitting something with the drill that would require digging it all up to repair things.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    What about drilling concrete anchors and bolting it to the concrete?
