Thread: AquaNaut® 200 - Need new tires, there are 4 options
    Apr 2017
    Miami FL
    48
    I need new tires for the AquaNaut®200.
    Looking at Hayward site, there are 4 possible parts I can look for (please see pictures below). No explanation on the web about the difference.
    10a seems to be the ones to get by elimination process .I'm ruling out 10b because by looking at the diagram those don't seem to have a "hump" that mines have. 10c because by looking at some pictures from the web seems like those are a different color than the other three options. 10d has a "finger hum" which picture seems little different from what I have.
    Does anybody has an expert opinion on this? What are the differences/applications between each one? I called Hayward support line but the representative was useless.
    Thnx,
    13K gal, IG plaster, 1 1/2 HP Pentair WhisperFlo, Hayward C900 cartridge filter, Taylor K-2006 FAS-DPD, Hayward AquaNaut® 200, built around 1979
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,418
    Re: AquaNaut® 200 - Need new tires, there are 4 options
    the tires are for different surfaces.. You can use the Poolvergnuegen tires as they are the same exact parts, Hayward bought Poolvergnuegen
    these are for concrete pools and have the hump to get over main drains
    https://www.amazon.com/Poolvergnuege...rgnuegen+tires
    Hope this helps
    Apr 2017
    Miami FL
    48
    Quote Originally Posted by cowboycasey View Post
    Hope this helps
    Thnx, just ordered them.
