Thread: Hazy water
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    376
    Hazy water
    Installed a new filter and hard piping this spring (pita, but done!) !00# of pool sand, backwashed several times.
    Chem levels:
    FC 7
    CC 0
    Ph 7.4
    TA 70
    CH 90
    CYA >60 (adding two more pounds, reagent refill on the way)
    Bromate >50 (I can't see the color change on the strips)
    The water is clear, no evidence of anything growing (did need to SLAM after the pump was out of service.)
    I run the pump 4 hours per evening with the swg @ 35%. But so far the water doesn't have the TFP brilliant sparkle I'm used to. There is a slight haze when looking at the white ladder against the blue liner. Am I just impatient? Or maybe run the pump a little longer? 4 Hours is what I ran last year with no issues. Or add some DE to the filter to scrub the water a bit more?
    Using TFP methods will ruin you for wanting the perfect pool water! I've had it before and want to keep it!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Jun 2014
    17,318
    Re: Hazy water
    Yes, we all tend to be a little more OCD now. While it may just be a matter of the filter doing its job, you could always do an overnight (OCLT) test just to reassure yourself there isn't excessive FC loss because of that suspected haziness. If you pass the OCLT and the filter seems to be doing its job, you could consider adding just a little DE.
    Feb 2009
    376
    Re: Hazy water
    Yeah, I'll do that just to eliminate any unlikely critters lurking in there. When perfection is attainable, anything less is unacceptable!
