Results 1 to 10 of 10
Thread: New (to me) house with my first pool
    Mar 2017
    Cordova, TN
    8
    Just moved into a new-to-us house (circa '95 construction), with the first pool we have ever owned. Knowing nothing about pools, I started reading TFP before moving in, got my test kit ordered, and was ready (kind of) for a new experience. I had to get a pool guy out here to show me what all the equipment and valves were for, but I knew enough from here to filter out all the "use copper algaecide, shock once a week, test strips are good enough, don't use liquid bleach because it's bad for the pool - use pucks instead," trash and just take away the mechanics. Good thing, because filter pressure was around 26, and he said it should be around 15. Cleaning it was a yucky, but instructive, experience. I think I'm going to have to get some new filter cartridges as they looked really beat up. I also get a lot of gunk in the polaris filter screen at the pressure outlet. Since that comes from the pump (?) I think the filters not working as good as it can.
    First round of tests gave me a CYA of close to 100, so I decided to partial drain and refill. Now that I have that done, I tested everything again and got these numbers:
    FC 2.0
    CC 0.5
    pH 7.5
    TA 90
    CH 75
    CYA 60
    Temp 76F
    My first thought is raise the FC. The TA and CH also need to come up. Should I Do it all at once, or tackle one at a time?
    The pool guy said that I have an algae problem. The water is pretty clear, but there is some clumps of green on the pool bottom that "poof" away like dust when brushed. I think after I get everything where it should be I may SLAM.
    Also, not confident on the pool capacity. Pool guy took one look and said 30k, based on knowing the pool style. I understand the concept of measuring the pool, but the deep end sloping really doesn't give me confidence in getting a good number. Maybe bringing the FC up will point to how accurate 30k is?
    I attached photos to show the pool shape and the slopes. The clumps of stuff that may be algae or something else are visible.
    Any help would be appreciated. Looking forward to getting the chemicals in control, and keeping them there without a pool guy!
    26k IG vinyl pool, Chlorine, Pentair 1.5 hp pump, Emerson Motors 1081 3/4 hp cleaner pump, Station-Rite System 3 S8M150 filter, 3 skimmers, 6 returns, dedicated pressure cleaning line, Polaris 360, heater (not operating), Vision VG mineral cartridge (not used), TF-100 test kit with SpeedStir. Memphis, TN area.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: New (to me) house with my first pool
    Must be a typo... 9 TA makes no sense.
    Low CH is no big deal with a vinyl pool.
    If you see algae, forget the rest of the balancing and SLAM it. When you're done with that, then worry about fine tuning the rest. It might only take you a day or two to pass all the tests if the algae isn't bad.
    Mar 2017
    Cordova, TN
    8
    You're right. Did it again. Forgot the multiplier. TA=90
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    656
    Nice looking pool. Get it slammed into shape, and share more pictures.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    May 2013
    Ontario, Canada
    63
    Those downspouts don't give me a lot of comfort? How is the drainage in a heavy rain?
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    Mar 2017
    Cordova, TN
    8
    Quote Originally Posted by carpenter333 View Post
    I don't think it's too much of a problem. Only been here a couple of weeks. There are two drains in the hardscape between them and the pool. I'll keep an eye on it.
    Mar 2017
    Cordova, TN
    8
    Well, that's interesting. By PoolMath I should have been able to raise FC from 2 to 24 with 8.1 jugs (121 oz) of 8.25% bleach. I dumped 8 jugs in, brushed the sides, and tested about 90 minutes or so later. Came up with a FC of 27.5! Playing with the calculator it looks like the pool is actually 26,000 gallons. At least that's a preliminary estimate, not sure how accurate. Going to have to get the wife to help me measure this weekend. Still not sure how to adjust for the slopes, though.
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by BlackBeard54 View Post
    Well, you're certainly keeping the FC level up!
    Mar 2017
    Cordova, TN
    8
    If the OCLT test in the morning indicates a drop of over 1.0 ppm, but FC is still over SLAM levels, I don't add chlorine but just brush and monitor, right?
    Mar 2017
    Cordova, TN
    8
    Drop of 1.5ppm, from 26 to 24.5 overnight. Not too bad. I see brushing and testing in my day.
