Piping fittings
May 8, 2017
102
Wolcott, CT
Plan on asking my installer to take out the frog system today and he may or may not balk at the additional pipe work as his plumbing guy likely won't be back to the site. Looking at Home Depot today in case I have to do the work, I could not find any of the o-ring fittings for my system as shown below. Is this specialty stuff? Thanks for any help.
Those are unions. As long as you can find a match plumbing in a straight piece of pipe will be a cinch.
Usually the fittings have some sort of branding molded into them. If you can determine that, it shouldn't too hard to find that manufacturer and then find an online seller.
Hard to tell from the picture, but, is that a threaded fitting into the chemical doser? if so, unthread the glued portion of the union and fit in a pipe with the 1 1/2" female threads on each end.
