Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: New Solar Panel design questions
    Oct 2016
    New Port Richey, FL
    13
    Hello all. I'm getting ready to buy and install solar panels and thought I would run my plan past those who know a lot more about these things than I do....just to make sure I'm not planning anything overly stupid. I'll try to include as much info as possible. I'm a commercial builder and have done much of the plumbing in my homes for years, I feel like I can glue a pipe as well as any apprentice plumber so will be attempting this project myself. The questions in my mind are design. I believe I've decided on Techno-Solis brand mostly because they are local and that appeals to me. Feel free to caution or wave me off if you feel there is a better option that a do it yourself type can get access to. I've read the install manual for them and a few others and believe I have a decent grasp on design needs. Pool is plumbed 1.5inch, two bottom returns and one skimmer. Pump has two inch from pump to filter and will be two inch to panels and back then reduced to 1.5 before going into the chlorine (may install SWG at same time). Intelliflow will be controlled by SunTouch though I am considering EasyTouch if for no other reason than it has a panel inside with temps etc and I can control the water features pump with it as well.
    Pool is just north of Tampa Fl, looking to extend swim season as much as practical. 16X30 free form pool, screened, shaded in mornings. It's May 10th and water temp is 78 and has been there a couple weeks. Took until August to heat up to the 85+ last year that the wife prefers...and didn't last long. Looking to add solar to get it there sooner and keep it there longer. As you can see in the photo below (I hope it shows up below...and I apologize for my horrific photoshopping skills), the run across to the best south facing roof isn't terribly short. Eight 4x12 panels in a double stack. 5 on bottom and 3 on top will pretty much fill that section of roof. Is there a problem with 5 and 3? In keeping the heated water run short I'm going to feed the rows from the right and back to the pool from the left. I believe I can maintain fall on the piping to allow drainage when system shuts off. Relief valve on the right side of the upper row.
    I'm sure I'll have questions along the way, but to get started.....If my drawing makes sense, does this plan look like a bad idea to anyone?
    15k IG pebbletec pool, Intelliflo VS, Two wheel ThePoolCleaner, solar cover, Pentair EasyTouch & IC-40 SWG, 8 panel Techno-Solis solar.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: New Solar Panel design questions
    Looks pretty good but I think you want the outlet of the lower row of panels to go up to meet the outlet of the upper panels before retuning to the pool. Other wise the upper panels might not fully purge of air. Also a 2" run to and from your panels is better even if it reduces back down to 1.5" going to the pool.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    Looks good. You may want your VRV on the upper right of the lower panel array so that less pressure will be needed to close it. You can even put it on the lower left of the lower header if needed to make it easier to close.
    I DIYd my Vortex/Techno-Solis panels quite a few years ago and it was not bad. There are pics of my stuff in my pool thread, link in sig. There was another solar diy thread recently with lots of pics.
    May 2016
    Woodland, Ca
    235
    The only thing I would add is if the picture is oriented so the top is north, you are using prime real estate for solar PV panels. That west facing roof may be an option for pool solar as well. My neighbors have west facing panels and they put a lot of heat into their pool.
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    Oct 2016
    New Port Richey, FL
    13
    Thanks guys. I'm learning as I go here and this site has been a world of help, though this is the first time I've asked any questions as search typically finds what I need. I will move the VRV to the upper right on the lower array. We have no plans for PV panels as I'm not generally a fan, but we do have lots of plans for a pool in November so the south facing roof is likely our best bet. CJ, I think I understand what you're saying...is this what you meant?
    40,852
    Welcome to TFP!!!!
    Yup, that is what he meant. Picture looks like a good plan.
    Try to be sure that the pipes and panels are always on a slope (or level) so that water will easily drain back down and not get trapped. I think that is feasible with your drawing.
    DFW, TX
    24,974
    Here is the recent diy thread, Solar Heater Addition in Baton Rouge, LA (DIY))
    FLPoolDIY's Avatar
    Aug 2016
    Land O Lakes, FL
    102
    Billiam,
    I have seven of the techno-solis panels installed with a similar sized pool. Like you, I live about 26 miles north of Tampa and was able to get my water to 85 degrees today. I typically see about a 4-5 degree increase in water temperature from the skimmer to the return. I'm not sure if that is a normal increase in temperature or not.
    FL, 15K gal (15x30 rectangle beach entry), IG Plaster, 2010, 1 skimmer, 4 returns, ecostar VSP, Pro Clean (PCCF-125) cartridge filter, IC20 SWG, Hayward Navigator floor suction cleaner, solar heat, waterfall, 2 lion head spouts, 1hp pump, TF-100 w/SpeedStir
    Oct 2016
    New Port Richey, FL
    13
    Ok, this is moving along nicely now. Panels are ready for pickup and I'm done with the pad plumbing, easytouch is installed and IC40 is running. I'm working on piping on the roof now which looks to be pretty simple but I've bumped into my next question.
    One of the install manuals I read said to use straps on the roof that are one size larger than the pipe, for expansion. When I look at the DIY thread, it doesn't appear like that's what he did. So....2" sch40 pipe...use 2" straps or 2.5"? Keep in mind we are in hurricane country. Thoughts?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    I think you would go with 2.5 inch straps. I was inspecting and cleaning my roof this past weekend and I noted that I could lift the pipes up about an inch or so, so I could wash the roof material off that had collected over time. My panels were installed by the manufacturer. Look at the thread in the sig bar
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Oct 2016
    New Port Richey, FL
    13
    The 2 1/2 inch straps my local stores carry are galvanized for electrical conduit. Is that sufficient?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    I think you have to get the special stainless steel clamps with the lag bolt. Did you look at my solar build in the sig bar?
    Oct 2016
    New Port Richey, FL
    13
    I did see the clamps used by your installers Brent. Pretty slick, but I have no idea where to source those. I'm not sure they are the only option either. I'm leaning towards oversized two hole galvanized pipe straps at this point, but I'm still very open to suggestion.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    I would call the makers of your panels and purchase the right hardware for installing your panels. Your want to make sure it does not damage your roof during a hurricane. Also you could look at getting some quotes to having it installed by professionals. I opted to for this as I have a lifetime warranty against roof leaks and 20 years on the panels.
    Oct 2016
    New Port Richey, FL
    13
    I decided to come home and do some research before buying the straps for piping on the roof. I spoke to Techno-Solis about it. They said standard pipe straps from Home Depot are fine for running across the roof and their install video shows the same. Aquasol's install manual specs either galvanized or plastic pipe straps. Heliocol's install manual says upsize pipe straps for expansion. Brent's clamps look great because they are single hole , but I can't find them anywhere and technosolis doesn't supply such things. I'm thinking I'll go with standard two hole galvanized pipe straps as Techno-Solis advises. They are based here in Florida so I have to think they have given this some thought. Ok, with that brain twister behind me....back on the roof I go.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    Post pics when you start your install
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    Billiam here is my aquatherm installation guide and they show the installation hardware. http://www.bestbuypoolsupply.com/med...tion-guide.pdf
    Also the diameter of the clamps are 3 inches
    Oct 2016
    New Port Richey, FL
    13
    Ok, It's taken a couple days but the majority of the solar system is installed. It's not a lot of fun to do solo but I managed. I still have to strap the piping to the roof in places which brings up a question. The first photo, on the left the return pipe runs straight down the roof for better than 20 feet. Thats a lot of water and weight hanging from that strap at the top. Is there any way to support it in the middle of the drop and still leave it expansion capable? I'm tossing around looping the nylon tie down strap around the pipe below the coupling and using a superclip to hang it. Bad idea? Even necessary? See anything else that looks obviously stupid?
    Oct 2016
    New Port Richey, FL
    13
    Well it is up and running. Easy touch was fighting me, wouldn't control the solar automatically but I was pretty sure I had the programming right. Finally hit the reset out of frustration and when it came back...works as intended. The shocking thing is how quickly the pool temp increased. Up several degrees already. Now to see if the solar shuts off as intended. Oh, and no leaks!
  20. Back To Top    #20
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,411
    Congrats you will love a warm pool.
